how to change fuel pump pict?
is there a diagram or thread on how to put in new but standard fuel pump, did a search but couldnt find any, thanks guys, having a stressful day, get 1 thing sorted abd something else goes:headvswal
  • 1 year later...
Bloody pain when you have big hands good luck boyoh lol :whistling:
Overall quite straightforward matey just make sure all the seals are airtight once you've finished :smartass:
Goodluck :winkiss:
thnx very much for that guys. no fuel going to engine. a friend of mine is working on my car, he suspects the fuel pump. checked few things. he actually gona remove the fuel pump now. now to get a replacement.
Have you checked the fuel pump fuse and relay?
yes. we checked, thats the one under the bonnet by the drivers side, close to the windscreen right?
Yep, but also in the drivers footwell is a relay which takes a signal from the ECU before completing the fuel pump circuit.
Also theres summit (can't remember what lol) in the rear quarter panel passenger side i think which deals with the fuel pump and it's gubbins!
I've not messed with a pump before, but assume you can put a direct feed to it to see if it works? this will then at least tell up if it's pump failure or a wiring/relay/fuse etc issue
Smithy
