April 30, 200917 yr Hi all i have just got a 300zx and dont know if its twin turbo or single its a 1992 2+2 the logbook just says 300zx turbo, ???
April 30, 200917 yr if its a 92 turbo it will be a z32, all z32 turob's are twin, does your car have headlight washers on the front bumper
April 30, 200917 yr Author Hi all yes mine is a 1992 z32, thanks all, just been outside fiddling with the motor, i should of just looked, i turned the boost down as it was set at around 14psi and with the fact that it is smoking thought its for the best, the smoke is mainly coming from drivers side exhaust, the backbox is connected by about 2ft of flexi pipe, the smoke is white, do you think ots the turbo that sits on that side or could it be pcv valve's or the flexi please say either option 2 or 3 lol, the smoke is cloudy white in colour can't see any light blue smoke.
April 30, 200917 yr Author also turned the boost down as the car scares the sh?t out of me when the turbo's kick in the acceleration is out of this world, the car seems to drive perfect and is very smooth, would'nt there be loss of power or lumpy running if the turbo seal had gone? anything i could check. oh and the oil is clean no mayo or anything. thanks all, Dom
