Reverse lights not working??
Hey guys
Reverse lights have stopped working?? I have checked the bulbs and the fuse all looks fine. Any ideas?
Ron
reverse switch on the gearbox? time to get ya multimeter out :)
Ah!?? My gearbox was swapped out a few months ago. And my car was previously an auto to manual conversion. I wonder if they forgot to connect something up?
I'm guessing that if I dont get any current at the fuse box then its likely the switch? or wiring from the switch to the fuse box?
Have they worked at all since you had the swap done?
I think you will find that an auto box has a different kind of switcing for the reverse lights than a manual.on a manual box the reverse light switch will be on the side of the gear box itself.could be the same on an auto box on a Z but in a different position so the wiring harness wont reach.I know that on some auto boxes the reverse light switch is up by the gear selector itself inside the car.
