Urgent-ish advice on the Auto-manual conversion, wire in the arch
right cars going in tomo morning, and ive only got tonight to sort this :wack:
cars auto, and goin manual.
what do i need to do to bypass the starter thing?
ive got this pic, but its a little vauge?
do i reconnect the big grey connecter?
it says need to connect the black/yellow to the black/white wire?
do i do this in the middle of the 2 wires, so that the both wires are intact at the big grey conectors? but meet in the middle
or do i remove the black/white wire from the grey conenctor, and splice to the black/yellow wire?
can someone clarify please, asume u just have a third bit of wire that connects them both together in the middle, whilst their are all connected to the big grey connecter?
I can't remember which pins it is but I remember having to join 2 together.
I think I soldered a wire between the two.
Was years ago I did mine though :confused:
um... ok,
this is what the guide says:
In the driver fender the black/white and the black/yellow wires are the ones that need to be connected. This will bypass everything.
but the pic confuses me a bit, as none look conencted, and there are some bits of solder, or perhaps he hasnt finisht on the pic?
That pic is a bit crap. I had a nice diagram someone did somewhere but I can't find it.
I seem to remember the wires to be joined were on the same connector?
It looks a bit like black/white and black/yellow are the bottom connector in that pic but like you say none seem to be joined?
All it's doing is bypassing the neutral switch that used to be there so if both wires are on the same connector then just solder a loop of wire between them on the back of the plug or if you have the old connector they used to go to spare you could cut it off and plug it on the end of your new harness and join those wires on the offcut... if that makes sense.
Edited by ChrisC
You can cut the connector of and solder the two wires together.
dont have spare,
if someone has the diagram, or can confirm exactly how to go about it be great.........
thanks legrath, so jsut cut the big grey block off yea, then conenct the 2 together?
think ive got it.....
ive got the gearbox out,
il stick to the wheel arch as i now know what to do :)
thanks guys :)
