cheap plugs
ok im sorted for plugs now.. got a pair of 6 for £41 before delivery.... result ^^
i ordered 11C as im standard however my car is missfiring at the moment and getting worse.... one thing i noticed is that the reciept for spark plugs changed ages ago were showing as each plug at £3. >.
hopefully when my new plugs come the missfiring should be solved :hyper:
fingers crossed... if not inspect the coil pack connectors and switch the coil packs around... see if the problem cylinder changes..
got new coil pack connectors and new injector plugs being made for me so hopefully come friday it will solve alot of problems.. only thing left if it still missfires is to check PTU (getting rep) and coil packs.
will keep you informed of what brand of sparkies went in when i get them out
When mine was misfiring last year...... I put on new coil pack connectors and injector connecters cause the wiring had gone "crispy".... still running rough.... so got some new coil packs....... still running rough....
Twas the bloody spark plug in the end:smash: and I'd only put it in myself less than 12 months previous!!:rolleyes:
yeah thats what i am thinking as the last lot were 3 quid each >.
