do you have too...
do you have too remove the turbo elbows to get the engine out or can you just undo the exhaust at the start of the catts??
mocal oil coolers, did I read it somewhere that this is a good upgrade??
I've got the cooler in the siver one:)
whats the oil stat, is it a gauge??
its an in line thermostat that opens at 80 deg, helps keep you oil at a nice temp all year round. fitted one on mine a few month back when it was really cold. i found that before, the oil was running at bearly 60 deg. fitted the stat and it now sits at 80 deg all day long
you will see it.
it looks like a miniture beer barrel a few inches long by an inch or so in diameter with 2 inlets and 2 out lets. it sits right in between the oil lines. you cant miss it.
there is another type thats incorporated into the sandwich plate if you have one.
