spacers!
cant find a uk seller of 15mm hub-centric spacers anyone got some? iv baught spigots now and the tyres are on the way just need the specers
Have you tried POTN.co.uk
They sell Eibach Pro spacers.....I believe the spacers for the 350Z fit the 300zx, but you'd had to call to find out.
... are these for the front or rear....what offset are you running at the moment and how wide are your wheels?
FunkySi - I have 18inch wheels 8.5j, ET38 all round..... If I fit these 15mm spacers to my car it would make my all round new offset ET23 right? In your opinion, would this new offset give a good stance, but not cause any rubbing/clearance problems?
Any other suggestion welcomed, except new wheels!
Thanks in advance....
Rears are of slight concern with those specs. Ideally for something like a 8.5" wheel at the rear, you'd be wanting something around an ET30 - ET35. My rears are 9.5" wide and I'm running ET35. Take off half an inch (equivalent to the outer edge size difference) which is about 12mm...so it might be close.
Fronts are about right. I am running a +20 offset and my fronts are 8.5" wide.
My advise would be to get some cheap-ass universal spacers JUST to check clearance on the rears and if you're satisfied, then get the bolt-on hubcentric ones.
FunkySi - If you are running ET35 with 9.5 on the rear, then in theory if I fit 8.5 ET23 on mine, I should have very slightly more outer clearance than you?
Do you have any rubbing issues at all?
Cheers for you help:)
Also, the pictures of your car on your rides section - the front wheels, was these pictures taken when the offset was ET25 or ET20? Its very hard to tell.....
They weren't all taken at the same time. Some are pre-spacers completely, but where taken at an angle where you can't notice. There wasn't a huge difference between having 25 effective and 20 effective. I just did it because I could! LOL There was a difference that I noticed, but I always focus on detail.
lol! silly me!! iv got a set of jeff and jamie now 15mm hubcentric doofers!! :duffer:
Yes.
excellent in wich case the fronts can have the new hubcentric spacers and the rears will go without, or maybe the non hubsentric ones would do for the back as they dont steer? iv never noticed judder from the rear when the old alloys were on and they didnt have spigot rings on atall!
Quality! :smash:
