Question about jonce`s knob
Well someone had say it:dance:...I thought I would ask here instead filling up the for sales with my questions
Anyway how easy/hard are they to fit. My knob as the overdrive button and the side button plus at the front at the bottom of the stem part of the knob theres a little lever that you lift up before you can put it into drive .
So thats 2 buttons and a lift up lever on mine
Does that knob he is selling have the lift up feature on it or does the lift up lever bit on mine at the front on the lower part of the stem just get removed with the knob .
Does that make sence?
Wolveszx
Edited by wolveszx
edit text
Same one a i have. over drive on the side and you push the button on top down to enable you to engage drive...
Neil
Anyway how easy/hard are they to fit. EASY
Does that knob he is selling have the lift up feature on it or does the lift up lever bit on mine at the front on the lower part of the stem just get removed with the knob . No you carefully leave the original 'Lift Up' leaver in place
Dave
there should be 2 screws on the stalk if i remember (ages since i did mine)
there is also a screw on the underside of the main button to release the park
it should then pull out (careful as its spring loaded)
then the wires are self explanatory
i can't remember if the screws are hidded behind a small cover
but get the auto stick into 2nd and you should see it clearly
This might help a bit!
Dave
