hmmm need advise
hi guys im thinking of doing a rebuild but not a full one
so basically i wanna fit some 88mm pistons recon the heads new mains and big ends then clean every thing and rebuild the engine
then with the car remove all the shit on there that is not needed ect
basically i wanna no if my stock turbos and injectors will be ok with that set up or do they need upgradibg aswell im not looking for massive power just a set chill out smooth ride :dance:
No, your stuff will be fine, might be worth reconin the turbos though, and maybe getting the injectors tested.....
Hey mate Ive got a set of stock injectors cluttering up my garage. You can have them for postage costs if it helps you.
They managed to run my Z1600 tubs at 375 @ the fly so they definately work!
Ron
As Darkside says they will be fine. So while you engines out how about
EGR delete
AIV delete
Carbon Canister delete
Plenum coolant bypass
EGR delete
AIV delete
Yes defo agree with all of those. Good opportunity to replace your Heater matrix pipes as well
Ron
hi ron yea that sounds good mate can you pm me your address and what the cost is and i will paypal you the money :)
EGR delete
AIV delete
yea thats what i was thinking about doing and also maybe getting rid of the cruise control and removed the hicas as mine has been bypassed at some point and the aircon removed :)
i have replaced 2 of them when i got the car as some asshole didnt connect them back up when the put the engine back in after the new turbos grrrr and with my hands it wasnt easy at all to put the pipes on!!!! :rofl:
