Hello!
Today I have searching and reading about 12-15 post in this forum and un aus300zx..but I have a question about these replies:
-Problem 1---> Fuel Smell when temperatures goes on 30ºC
-Problem 2--->High fuel talk pressure (fuel system failure)
-Problem 3--->Problem with idle (I suppose because any vacumm line)
Are true??, false??
Now I have purchase Stillen SMIC and I have the car like this:
And I need to make the relocate..
And now, I need to know if relocate Carbon canister or make this..
http://s95014253.onlinehome.us/63104/197828.html
or
And...Do you remove CC?, Relocate?....I don´t know...:shock:
Oh, thanks...I have read this URL but....If bypass like this, is there any problem with the increasing of pressure in fuel tank?
No it will be fine. CC is just another emmisons thingy.
I removed mine.. took about 35 mins.. using the link above... really easy to doas well....
:D
Oh!!thanks!!:dance::dance:
If I have any problem, I will post here to ask you....:tongue:
PD:Bonus PIC (I will try to make a Spray IC controlled with AEM AFR)
ecu controlled water injection you mean? Sounds like a good little project. There is a kit you can buy that does this which im still to fit.
i see my old pic's are still floating around, i've had no probs with it removed
Slightly off topic,, how you been mate? You at any of the next meets?
Yes, Intercooler Spray controller with a microcontrole who I will program (PIC), a Analog/digital converter (because the signal of the AEM AFR is 0-5v), and a fuel pump with these "jets".
I want to make myself because the total cost will be around 10 Pounds...and I want to learn with the mod´s of the car..LOLOL
I will post pics when I have more information..
or you could get a smaller carbon canister . off a nissan pintara or a silvia.. there tiny and do a great job
and the diferent with robo´s page is this one?:confused::confused:
What is the difference between these pics running?
-Robo closed the tube
-You open with a filter to Atmosphere
Thanks guys
I prefer remove completely if the smell of the tank isn´t high....
Thanks!:nana2:
