suspension - really need some help
- Replies 28
- Views 1.4k
- Created
- Last Reply
EvoluZion3 11 posts
j1mmytt 5 posts
radron 3 posts
taff 2 posts
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
in desperation, i need some advice on my front wheels and them scrubbing on the suspension.
the story goes - ive recently got some 245/19s on the front (to replace my 225/18s). now the problem is that theyre right up against the elbow joint in the first picture, and i mean the wheels are almost being prevented from going to full lock. the first picture shows that even with that side of the car jacked up i can barely get my finger in the gap between the tyre and the joint - it doesnt look it but that's crushing my finger!
needless to say that when going over even the smallest bump, i get some horrible rubbing sounds (oddly enough only from the offside though - yet both sides have the same 'zero' clearance)
also needless to say ive only done about 3 miles in it since the wheels went on
my idea was to space the fronts out 20mm to give the required clearance, but (as you can see in my other thread) the stock hub thread is slightly too long and doesnt sit inside the alloy, leaving the alloy not seated upon the centre of the spacer properly - so i'll have to go 25mm to overcome that problem.
even with the 20mm spacers on (and the wheel kind of held in place) you can see from the 4th pic that there's still not a lot of room to play with
...but by going 25mm on the front, it seems that the tyres will be almost by not quite outside the arches and therefore being illegal.
so my exasperation is: how the hell have those of you (you know who you are ;) ) with 245 up front overcome these problems? surely you have sufficient clearance between the tyre and the (u-join?) - and if you spaced them out, how come the rubber's not spilling outside the car? :confused:
could it be that my stock suspension/geometry is just fooked and causing this problem?
id really appreciate some help on this one gents as ive just gone from a high (bodykit next month - NA subframe on way, etc.) to a 'i cant even drive the barsteward thing'
