poll to see how many still run standard boost ?
what boost mod ? 58 members have voted
  1. 1. what boost mod ?
    • standard
      46%
      27
    • Electric boost controller
      34%
      20
    • mig jets
      15%
      9
    • other or not sure
      3%
      2
Running boost jets and an upgraded ECU, not sure what the boost is at now... and not had the chance to test the guage out.....
My old zed was running 15psi, which was nice :) New one is standard boost :( Well until I put my old engine in it :D:
EBC as from today :)
It would also be interesting to know what types people use.
Mine is a Hybrid developments SBC-D 13.5psi
Edited by petes21st
standard now but as its all running fine and dandy i'm gonna install a mines chip and boost jets 1mm, and fit the stillen ARB kit and some new tension rods. Should handle nicely then.
Chipped ECU with jets as you know Paul, cos you fitted them:)
Had to reply 'other' for me. I have different waste gate actuators (which open at 16psi).
Si.
Jets for me, as i didnt realise i was running safety boost when i first got the zed, now im not, need new uprated clutch very soon.
apexi - avcr EBC for me running 13 psi atm but when its back will turn it up to 14.5 psi
Mig Jets ? As in 29 :)
Now that would be interesting to see on a 300zx :)
Standard at the moment, but in the process of installing a boost controller, chip, down pipes and decatt pipes. Also removed EGR, AIV, changed pcv valves and o2 sensors.
EBC - Greddy Profec B Spec II.
Supposed to be set to 12.9, however the dyno sheet shows it peaking at close to 15!
However it should be running a little more than 12.9 now anyway as i had a couple of boost leaks fixed :D
