water in passenger footwell
iv got water in my footwell its coming from the targa drain hole dont know how this happened or how to fix well i have an idea or 2 but just wondering if anyone has had this problem cheers
serch is your friend......
:D
Load's of ppl have had this problem, a member had it recently.....
Yeah me :mac1:
Was a right PITA to sort out..lol
As mentioned mate, have a search for "targa drain plug", that'll help you out.
You sure its from the targa`s, the pipes run down the A post and emerge at the front of the sill section, the rear drains run close to the B post and also emerge out of the sill, unless these pipes are split they dont normally directly leak into the cabin.
Check the heater matrix, and if ok you need to remove trim to inspect the pipes.
Jeff TT
Jeff TT
Doesn't the matrix normally soak both footwells though Jeff?
It might be the A/C drain.
could be the air con drain pipe which is on the passenger side
Mmm.. can do either or both, depends on the location of the leak, good point on the AC drain often overlooked, behind the wooden panel hiding the ecu`s.
Jeff TT
defo comin from targa drain thanks everyone for your help this problem wont get me down for much longer i have to say ths site is rather good hope to meet some of you sometime if there are ever any meets in scotland
stephen
