Brake disks.....?
Can anyone please recommend a make and where to purchase. I have a standard brake set-up, but as the fronts need replacing, I might as well do all. I fancy vented? Mnay thanks. Tony.
Hi mate
Dan at DTA does good brake parts by DBA they are grooved or vented I believe
As said by the two above - Dan is your man ;)
DTA Motorsport in znut's link :)
Hi Tony,
As stated above by everyone else (thanks guys!) I can supply you with both DBA or 3G discs. There are a number of permutation available for each so you are best off having a look at the following page on my website which will explain one or two things: http://www.smithys-place.co.uk/brakes.php
FYI: 3G disc are brembo casts which are then grooved (and/or drilled) in accordance to 3G's own specifications. The DBA discs are also excellent discs and can be purchased in a number of different configurations and materials. If you are looking for just stock replacements then I can recommend the 909/908 discs. If you are looking for a slight upgrade then the 4000-series is your disc of choice.
If you need any further assistance, please let me know.
Regards,
Dan
:hyper:Cheers to all that replied, it looks like DTA's the way to go.
Dan, expect aphone call.
Thanks all. Tony
imho, i think that standard 300 brakes are s**t, just my opinion.
i would, if you have the money, upgrade k-sport 6 or 8 pots with discs to match.
get rid of the abs.
then ur 300 will STOP!!!
or, if you dont want to spend too much, go for the relocation bracket with larger discs.
many members here may dis-agree with me, but this my opinion.
al.
(you can take a look at my 300 matey poss this weekend, if u r around)
