As the title says .........today I had the Zed up on a ramp for the first time since I bought it back in November.
1/ NSF tension rod bush is leaking oil - can I replace the bush or does a replacement rod have to be sourced?
2/ Auto box sump pan is leaking - will have to replace gasket and may as well do the filter and fluid change at the same time.
3/ Rust .............both rear outer wheelarches need replaced, OS outer and inner sills and NS inner sill are holed enough to fail the next MOT :rant:
Other than that - it doesn't look too bad :) although I'm sure that the cost incurred in replacing what will probably be inner and outer sills (both sides) and wheel arches will be frightening. :(
Any ideas of the cost of inner and outer sills and am I best buying Nissan or pattern parts.
Hi there,
Thanks in advance - Andy
