900brake 300zxtt yes with vg30dett in it
of ttnet
Standard block-rebored 020, plate honed, o ringed, deburred, internal polishing, decked & line bored
cylinder heads-ported, triple cut valve seats,nismo hydraulic lifters, custom wade cams (my specs). Nismo vernier intake gears and custom vernier exhaust gears.O ring receiver groves
Con rods- billet Eagle H beams, x rayed, crack tested,
ARP Bolts
Pistons- Custom JE with Hastings rings,8.0/1 comp
deburred
Crankshaft- Billet Sainty built with rolled radius, Knife edged and nitrided, balanced, crack tested
Main girdle, Billet steel machined 2" thick to outside of block, studded main caps and thru bolted to pan rail on block.
Custom intake manifold with 6 50mm throttle bodies, Custom intake plenum with ram tubes
Custom exhaust manifolds
Twin Garrett GT35r turbochargers with modified exhaust housings
Custom alloy intercooler plumbing
Custom GTR spec intercooler
Custom 3" dump pipes to twin 3" exhaust
Custom 4" alloy air intake & remote filter
Custom alloy vacuum tank for brakes & clutch
Custom alloy breather can
Earls braided hose throughout
ACL main & big end bearings
Copper head gaskets
Custom stainless swirl pot
Twin Bosch motorsport pumps,Twin 5/16 fuel lines, Malpassi regulator, 7/16 return line
6x 720cc injectors
NIsmo flywheel
OS Giken twin plate clutch
Single piece tailshaft
Custom copper, reverse flow radiator
Autronic SM2 with 6 coils running full sequential injection,
Antilag & rotational idle.
Hell, even the oil filler cap was custom made!!
Custom baffled alloy sump
biggrin.gif biggrin.gif biggrin.gif all i need now are the blowers he he i have the rest biggrin.gif
well and the intake, uuhmm of ocurse also a working engine lmao
[This message has been edited by 300z (edited 04-10-2002).]
biggrin.gif biggrin.gif biggrin.gif biggrin.gif biggrin.gif biggrin.gif biggrin.gif
Wonder how much that would cost to build?
That's been posted before -how about something original ?
A: What does neone reckon the 0-60 would be for that?
B: The air intkae looks a bit like a Japs Eye !
Originally posted by Mike Duffy:
Is there a doctor in the house?
Nee nah nee nah...woooooooo woooo...nee nah nee nah...screeech! "Doctor Turbo here, what seems to be the problem?" biggrin.gif biggrin.gif biggrin.gif
"Life sucks. Get a F**king helmet, okay?"
Denis Leary
Hello Doctor
The end of my member appears to be cone shaped and perforated. Is there anything you can do for me?
ok sorry for those who never saw it before.
Lmao.
Does it actually matter if its a repost?
I mean i havent seen it on here before?
Hello Doctor
I told you to get the Blitz induction kit and not the HKS you fool!!! ROFL biggrin.gif
Denis Leary
Someone told me it would increase the airflow. Should I have installed it on my car instead?!!!
What type of Doctor is this lol,
Never seen that posted on here before,
that engine is awesome!!!!!!!
He must have a custom bonnet, as the custom intake plenum is quite high
wonder what the bonnet will look like, recon something like the JUN bonnet?
he he if my engine looked like that id drive around without a bonnet lmao
Was on a USA motor site other nite,was reading about a guy putting a RX7 engine in a Z32,going for big ,big power,cant understand why!
A very good friend of mine put an rx7 engine in a nissan 200sx, did a hello of a job, goes very well, and makes decent power , used the greabox aswell.
I'll try and find the site!,i have a feeling that this guy was on about putting 2 RX7 engines in?,seems to ring a bell with something i read,believe its been done on other motors!
Denis Leary
