  • Replies 30
  • Views 1.1k
Absolutely nothing to do with Zeds, but my Dodge Ram in lock up (top gear)
does 38mph for every 1,000rpm.
V8`s are lazy.
Alan.....
i dont get the conversion. the wider the tyre the theoretical top speed increase???
i put in 17" wheels at 235 wide @ 45 profile and it gave me a top speed of 176.7 mph at a 255 wide tyre it goes up to 181?!?
well i thought an na wouldnt go that high?
The tyre profile is a percentage of the tyre width . So 45% of 255 results in a bigger sidewall and larger circumference than 45% of 235. You need to lower the tyre profile to correct it.
It would with enough power and the larger tyre size you gave....although check the rpm I think I might have put it higher than stock.
so a 235/45/17 wheels is what percentage?
Edited by hellraiser
235/45/17 means the tyre profile is 45% of 235.
To retain the same diameter/circumference (or as close as possible) when fitting a 255 tyre, then you would need to fit a 255/40/17
The link Tonyb posted is very handy for working out the correct tyre sizes to fit.
Edited by Yowser
The link Tobyb posted is very handy for working out the correct tyre sizes to fit.
gotcha!:D
No way is the tyre 105.75 mm tall!
Well my TT on 18's does like 32mph at 1000rpm so :P to your figures
with your 265/35/18 rear wheels its doing 27.1 mph per 1000rpm.
Edited by Yowser
Quote:
Except it is ;)
but what dimension of the tyre is that exactly? If it were the tyre walls either side of the wheel added together then that would seem to fit, making the distance between the outer edge of the rim and the outer edge of the tyre 53mm(ish).
thats what i would say it is. tbh i thought the 45 was the side wall in mm so i thought mine were 45 mm high?! doubling that would be 90 mm so i wasnt far out LOL
so its the side wall x2 which is 45% of 255. is that correct, tyres hasve always confused me. so do offset messurments
Well my speedo is bang on with GPS till about 60mph so f**k knows :tongue: all lies i tell ya lies :tongue:
no, it is the actual height of the sidewall as a percentage of the tyre width
235/45/17 sidewall height is 105.8mm (10.5cm)
Edited by Yowser
I've made a scale diagram of a 17inch wheel with a 235/45 tyre, one going on 106mm tyre wall, and the other 53mm wall:
I just popped outside and quickly measured a stock zed wheel -
245/45/16 and it came out at just over 10cm on my crappy kids 15cm ruler.
