Error code 33??
Car has low power and i did ecu test, came back code 33? would this put it into safety boost? not sure what to do now? ive tried searching this code on here but cant find any other posts?? help
Cheers for that, would it be in safety boost because of this code 33 ?????
O2 sensor
Sorry i can't help any further :(
I'm sure help will arrive swiftly tho :)
no mate
Gavo, the fault indicates a failed 02 sensor as Znut mentioned, as a get you by for now disconnect it at the back of the engine the ecu will then resolve a fixed but constant figure, which is the better of two evils rather than a fix.
To get an error code the sensor or cable must be short circuit as even a dead on e will rarely cause an error code.
Safety boost cannot be caused by this O2 fault, lower than normal performance can be cause by many things and a ConZult diagnostic is the only sure way method of sorting it, ask if any members close by have one.
Get the sensor swapped after Xmas when you have more time.
Meanwhile MERRY CHRISTMAS
Jeff TT
Hey thanks for that guys, hopefully itl sort the 7 mpg out as well!! as thats all its doing. il post a new post and see if anyone can help with the conzult thingy, and merry xmas to u all too
