Hey everyone, the car is nearly back on the road. Just need some new brake discs, but not sure which ones to get, any ideas?
(not looking for expensive ones!)
have been looking at these:
http://www.smithys-place.co.uk/brakes.php
3G (300ZX TT only):
Front - 20 groove set £210.00 BRA028
Or try Zedworld.... I think they use the same a Smithy..... Smithy and DTA are both good as well as Zedworld
Hi!
The 3G brakes are very good discs. Brembo cast and top quality. Usually available through us (ie, DTA & Smithy's Place) within a couple of days. Alternatively the DBA discs are highly recommended.
However, what brake pads will you be using with these discs? The pad material and disc composition is a major factor in how well the system performs. I can recommend Porterfields and DBA 2500's (also available directly through us).
Let me know if you require any further assistance.
Regards,
Dan
I have DBA's on mine and can confirm they are excellent, look the nuts as well.
Went for Mintex Pads though which squeel like a b*tch. May look into changing those....
