In memory of Mandy
leaky door rubbers!
im having a bit of trouble with my door rubbers slightly leaking.i come out in the morning to find little puddles on the top of each door card.ive been told its common but i havent been told how to fix it.any ideas?and is there an easy way to get rid of the jap speed limiter i think its time it come of:D
Think you will find this might be the Tagra rubbers, mines started doing it on the passenger side, when i opened the passenger door the rubber from the Tagra is hanging down a bit, just make sure that it's secured to the pannel properly...
Cheerz
Neil
yeah i think its them ive just noticed they sell them on zcentre.co.uk they are not cheap but itl be money well spent.
TBH nothing int eh Zed centre is cheap.. but these arnt cheap cars....TBH if it's hanging slightly i would try and secure it first before replacing, it may just need sticking back on.....
As for the speed limiter mate, does your speedo read in KPH or MPH? You can get a cheap and pretty easy to fit converter that connects inbetween your speedo and the ECU (behind the speedo) and that converts it, and removes the limiter, IIRC, but if it's already reading in MPH, then not sure, ECU remap? I'm sure somebody else will know soooo much more than me :-)
