Correct tyre size for my Zed?
Hi Guys n' Gals,
Now, I only bought the Zed last weekend and today was only the second real chance to look around it in the daylight.
Front tyres are Goodyear Eagle F1s - 245/40ZR18
Rear tyres are Goodyear Eagle F1s - 275/35ZR18
Is that combination ok for the car?
There's no problem, it drives fine, I just want to ensure that I'm running with the correct size tyre and wheels. Having said that, I did notice a rubbing noise from the front when using hard lock to reverse into my drive today :confused:
Advice would be most welcome - Thank you.
It depends on the width of your wheels. Have a look on them, they'll have 8J, 8.5J, 9J etc etc stamped on them somewhere. This is rim width in inches, the tyre is then selected to suit this.
9.5 - 10 rear the rears usually requires 275 or greated. If I had 10" rears, I'd have 285s. Currently have 275 on, on my 9.5" rears. I'd not go any narrower. I did have 265s on the back, but they looked stretched. I don't like the stretched look. Flat tyre walls is what looks best.
I too have 245s at the front and I'm running an 8.5" fr. It used to have 235s on them, but again, had the stretched look to them.
You may get a little rubbing on full lock but if is only on full lock like mine at very slow speed dont worry about it.
I run
19" Rims with Falken FK452 Tyres,
Front Tyres : 235/35/19
Rear Tyres : 265/30/19
Edited by Phantom2080
I run
What width are the wheels though??!!
Okay guys, thanks for that.
Now can someone hazard a guess at what make of wheels they are?
They look like Devil AX147.
I haven't got round to taking any of them off yet, maybe in the next couple of days if the weather doesn't get too cold. :)
Front 8.5"
Rear 9.5"
Sorry if I sound a bit dozy - but how do you know what size they are? :confused:
just went outside with a ruler and measured them on drive with two torches width across to be double sure.
There's dedication for you! :bow:
no worries mate only got me z back yesterday after being in a mates garage with a broken water pump now running sweet as again.
Front tyres 8.5"
Rear tyres 9.5"
I'd be going up a size IMHO. 245 and 275 respectively.
Emm, that's what's on it at the moment. :D
I wasn't talking to you, which is why I quoted phantom2080!! :p
