injectors
hello how do you no what injectors you have as i have seen you lot saying im gonna get some (563 injectors ) ect not that i no the numbers lol
the colour of the connectors on the top of them usually give a clue to if they are stock or not
cool do you know what coulors =
eg
red = 123
thanks
Stock are 370cc. The picture only shows 1995 onward stock injectors which are different to the earlier style.
Earlier style stock 370cc injectors havea brown/green coloured connector tip.
Edited by Yowser
Earlier style stock 360cc injectors havea brown/green coloured connector tip.
legrath are they different in fitment or just cc?
can you see whitch ones you have without taking them out?
Just about, yes.
But be aware the colour *may* change over the years. I think Eric/Lymon said something like this some time back too.
look below and in between the plenum and there is a fuel rail they are attached to that.
stock 370cc are purple when new, in time the will fade to brownish/green
Nismo 555cc are purple when new, in time the will fade to brownish/green
so in short you will not be able to visually tell what kind of injectors you have...you can only tell if they are old or new injectors by the colour.
Most reliable way (imo) is by looking at the data in the ECU, the socalled K-value tells you what injectors the ECU is programmed for.
The conzult software will show this K-value.
-Eric
