Paul@SWZ
Everything posted by Paul@SWZ
  1. None of Shock Asorbers tightened up (Pj assured both myself and Helen seperatley that these would be torqued up) YOU FITTED THESE YOURSELF !!! O/S turbo bolts missing (Cant Guarantee these were not missing before) YOU SAY IT YOURSELF! Gaskets / sealant missing from both down pipes where they meet the turbo elbows (Exhaust was removed by PJ to fit engine) NOT NEEDED THEY HAVE A SEALING RING AND DONT NEED ANY EXTRA ! Missing exhaust downpipe flange nut (As Above) WAS IT BLOWING/LEAKING ? Front brake calipers are seized on (Due to length of time car was sat on axle stands) AXLE STANDS WOULDNT MAKE ANY DIFFERENCE ! Gear lever support bracket missing I HOLD MY HANDS UP TO THIS ! Exhaust heat shield missing WASNT ONE ON EITHER ENGINES ! Dump valves not connected ( no recircs either) ANOTHER JOB DONE BY YOURSELF ! Air con outside sensor missing ( YOU ) Air leaks on engine plumbing (WHERE? ) Idle speed incorrect set up YOUR ENGINE ! Throttle and cruise control cables too tight NOT LIKELY ! Aiv supply pipes mixed up at throttle Brake fluid below minimum limit NOT MY PROBLEM ! Fuel filter bracket bolts missing YOU REMOVED THEM FOR THE PETROL PIPING YOU FITTED REMOVED ! Front shock absorbers both loose at top mounts (see point 1) YOU AGAIN ! Cooler bracket insufficient (Cable tie job by SWZ) YOU AGAIN REMOVED SOMETHING AND EXPECTED SWZ TO PUT IT BACK ON !!! Both front ABS Sensor wiring insecure resulting in ABS light not working. NEVER WENT NEAR THEM BUT YOU MIGHT OF WHEN REMOVING SHOCKS !!! NON SWZ related Rear Discs excessiveley pitted Fuel pipes Corroded Brake Pipes Corroded Offside & nearside subframe mounts excessive corroded Offside & Nearside front and rear sills excessive corroded Parking Brake has no reserve travel No Main beam Front reg plate too small 4 Wheel nuts missing All I was aked to do was swap thre engine but you kept removing or changing stuff yourself and not putting it back properly and was not my responcibility to rectify ! I welded up your van also as part of the deal as well as welding the seals and putting your silver car through MOT more welding ! I dont need to come on here and justify my actions conscernung your car but the fact you blame me for stuff you did kinda upsets me :rant: !
  2. I will be at work Matey but will come down and see you asap !
  3. We like kisses X X X X
  4. Hey mate hope to see you soon. ;)
  5. Can anyone that has any outstanding issues with SWZ or myself please PM or post here ! As far as im aware everyone should have every item they required and all people with outstanding work should of had contact from myself or dave ? Marcus give it a rest ! I did not sell you the car and i did not break my side of the deal ! I was asked to swap the engines which i did im sorry it took so long but other issues with suspension etc were the parts you removed and refitted yourself. Any problems you have with your car being a death trap is rubbish as I knew exactly where the car was going Zedworld and didnt see the point in rectifying faults caused by you !
  6. I think you will find there is two sides to every story and i am fed up with defending myself over and over again in regards to this car and deal !
  7. hopefully you guys will have everything sorted by the end of the week in either parts delivered or refunds etc ! TBH i have given up with this forum and SWZ and its only my loyalty to you guys that is making me sort all your problems. Dave is now in control of SWZ and is starting to get to the end of various problems and complaints but he will so just bare with him and contact him if you have any queries ! Again i apologise to everyone and hope everything ends well Paul
  8. check the water level and see if there is hot water running through the hoses at the back of the engine that go through the bulkhead ?
  9. track time please !
  10. spent about two hours chatting to him the other day and yes he is mad LOL
  11. HAPPY B-DAY matey !!!!
  12. Paul@SWZ replied to Soniazx's topic in Events - UK
    Welcome and thought you would like to know that burnham has about 6 zeds locally !
  13. does the gear stick itself come out of park ?
  14. spoke to helen today marcus !
  15. Sulking With Zeds !
  16. Marcus your car is still here and i have no missed calls from you ! also southwestz hasnt been around for about a year !
  17. Not true Dave, all the parts related to what you mentioned are the same. Except for spring rates, which are slightly (but not really noticable) softer on the Jap. yeh, some zed;s drive a lot better than others, but nothing to do with Uk vs Import.
  18. lol i have seen it before but he did ask before he posted it !
  19. happy B-day matey have a good one
  20. car is parked in yard that is the drive down the side of the garage with cctv watching it ! send a truck whenever you can !
  21. same place and postage is £8 per head !
  22. Not likely guys at home with my kids drinking tea LOL
