vance5868
Everything posted by vance5868
  1. They say if you get a load of petrolium jelly on your finger and shove it up your bum ............... no no sorry got it wrong , up your nose it helps
  2. Old blokes with nylon shirts and no deoderant should be hosed down in public with detergent ....sick of it !!!!
  3. hi hope you dont mind me asking , but what was your original prob ? was the stearing getting hard . mine is and i have changed everything including the pump without success . im now begining to wonder if it could be the pipes ? ta
  4. torque converter - drive plate - prop shaft - and gearbox is longer
  5. vance5868 replied to a post in a topic in General Discussions - 300ZX Related
    Swap to a manual gearbox ...........been there got the tee shirt , two auto boxes later , still no joy , converted to manual , Happy as a pig in poo now !!
  6. well i`ve swopped the power steering pump and its still the same ........... looks like ill have to find a rack ??????
  7. yes i left the man one in the man box . i am going to check the voltage at the solenoid on the rack in the morning . to try and narrow it down
  8. a did a auto/man conversion . all there is on the man box is speedo drive and reverse switch , so the power steering must take its info from the speedo drive ?
  9. there is no revolution sensor on the man box . not sure what it does though
  10. that what i thought but the speedo works fine ?
  11. After about 15 mins driving the power steering goes stiff , slow down and it gets better , fluid level , belt tension , all ok ?????? all ive done lately is swop from auto to man box . Its N/A so no hicas
  12. My springs have seen better days , front ones mainly, the car sits a bit low and it seems a bit firm on the ride . Would i be better off with after market ones or standard . All i want is to improve the `ride`feel and lift her up a bit . What you think ?
  13. http://www.driveshaftservices.co.uk /index.htm Give these a ring ,Tel: 01656 741 999 Fax: 01656 741 988 very helpful
  14. vance5868 replied to a post in a topic in General Discussions - 300ZX Related
    Yep ! But you need to change the engine drive plate /torque converter/ front half of prop shaft/and trans ecu all from a TT ( gearbox mount you can use from your NAbut you have to spin it 180%)................. top tip though convert to manual !!!!!!!!!!!!!!
  15. Now thats a weird question !
  16. Now in correct forum , sorry
  17. has any one got a prop shaft for a turbo ? dont need the rear half or the support bearing , just the front bit . pleeze !!!!
  18. If its the motor , i have one you can have mate . FOC !! just pay the postage . rsvp
  19. Hi Andy sorry i didnt make myself clear , i dont mean the engine management i mean the auto box control ecu . Reason is i am thinking of swapping a N/A Box to a TT Auto box , so might need the ecu (for the respective box ?)Cheers
  20. Any body know if the auto twin turbo ECU is interchangable with none turbo ECU ( gearbox control not engine management) Ta
  21. Looking at about £1500 to supply and fit , drive in drive out with all the bits . Its not a straight forward job
  22. Hi, Im looking for an auto box to replace mine (n/a) and the only ones i can find are TT . Are they interchangable ?
  23. vance5868 replied to a post in a topic in General Discussions - 300ZX Related
    Just a thought , i wouldnt put WD on the caliper rubbers cos it damages them . Only use propper silicone grease.
