ecu swop
Any body know if the auto twin turbo ECU is interchangable with none turbo ECU ( gearbox control not engine management) Ta
Eh ?
I reckon you can put a TT auto ECU in a TT manual, NA auto or NA manual car (would need to change the maps for the NA though)
You could also put a TT manual ECU in an NA manual car (once again need to change the maps though)
AT gearbox ECU is not (directly) interchangable between NA - TT
Electronically these gearbox ECU's are the same, but also contain an EPROM which is specifically programmed for it's application. (different gearchange points, linepressure, etc.)
Hi Andy sorry i didnt make myself clear , i dont mean the engine management i mean the auto box control ecu . Reason is i am thinking of swapping a N/A Box to a TT Auto box , so might need the ecu (for the respective box ?)Cheers
