krsmayo
Everything posted by krsmayo
  1. you have to put this sofeware on through a pc
  2. i think thats what i'm getting
  3. if this free xbox live thing works out then microsofe can go f**k
  4. the chip has a switch u use when you go on xbox live, i'm getting some software that uses xbox live for free, i'll let you know after the weekend if it works
  5. you can add bigger hard drives,play copied or imported games, play DVD's with out the remote and it has Divx and more, chips only £35
  6. mines chipped and has 120gig hard drive and a blue fan on top
  7. yeah could have had the french version too anout 2 months ago , but waited for the english one to raise its head, and now its hear
  8. Got it last night ,Back up copy, its the tits, and now you can hold two guns at the same time so no need to hide when reloading lol,
  9. just got back from lanzarote, saw a 350z out there the only z on there. left a 300zx flyer on the window, did anyone post on hear from there?
  10. give u better access to the forum,ie post up images etc. u get discount from the traders etc, its a great pool of knowledge for £20
  11. isn't it Stuart SMW1 lol
  12. I'm off to lanzagrotty next week, so i'm not around for a week or so
  13. I'll mail you when i'm home can't use work mail, I'm in Ware in herts, SG12
  14. I have an old set if you want em
  15. mine stuck on the white dials,make sure they are stuck down around the middle, i had to file the needle on the rev counter,the tailend of the needle was sticking, very tricky and i had a very small file ,you could use a small nail file but be carfull, hold the needle firmly. works fine now, some kits are thicker
  16. No don't think so,
  17. the engine turns over just doesn't run, ECU Code 55 so all's right there, just wondered if the CAS wires are damaged would it still run!
  18. A mate of mine's friends just got a Z (N/A), but after getting the water pump changed it wont start, he's getting a spark on each plug and there seems to be Petrol as the plugs are wet when taken out of the head.you can hear the injectors, it just wont start,I've checked all the connectors and all are really clean. any ideas, if the CAS is f*cked would cause a non start.
  19. krsmayo replied to a post in a topic in Events - UK
    sorry chaps would pop down but on holiday as from the first, lanzagrotty
  20. mines just a plane switch, Don't think MOT places will remember all the rules about a fog light switch
  21. mine only comes on with the side lights just pick the feed from the light switch controlls
  22. Oh it passed the MOT fine with this, you can use a red bulb, i did try one of those really bright LED ones but they only give out a focused beem so no good.
  23. i wanted to keep the full brake light effect, so i put some red photo film inside one of the reverse lights,all you do is cut a square to size roll it up as push it throught the hole where the bulb goes, it should open out flat inside, and then just re wire one of the reverse lights as a fog. Bingo
