Paul Thompson
Everything posted by Paul Thompson
  1. Ditto, just hold the revs up a bit now and again when stationary ;)
  2. What colour are they, a lot can be told by the colour of them
  3. Quick, cancel all cards and change all internet log in and password details
  4. I'm looking for both the Top Gear 6 (I think) Z car line up and race and also the 300ZX Land Speed record on the Bonoville (spellning I know) salt flats speed record but can't find either, anyone help :) CheerZ Paul
  5. There is a hole (IIRC) at the back of the targa opening, basically level with the back of the door where the drain is, make sure this isn't blocked. If I'm wrong, forgive me and someone will be along to correct or aggre with me :)
  6. Stock oil pressure guage is sh!t As for leaking Targas, check the drain tube isn't blocked
  7. I'm sure he will :headvswal Just going through possibilities :nelson:
  8. This is well worth checking/adjusting The RPS clutch is firmer than stock and you 'may' have had a weak fork which 'could' have bent when you removed the stock and fitted and used the RPS
  9. What does Mr Slick Pete have to say ? I'm liking it myself :)
  10. FYI. For a 5 second start, 15 - 20 minutes driving is required to get the battery back to where it was before start. Mine is flat and no matter how long I leave my charger on it's always flat the day or 2nd day after. After a good drive however (1hr plus) it's fine after that.
  11. http://www.admiral.com/splash/multicarQuote.php :nelson:
  12. That's what you/I said LOL :duffer:
  13. What a great find ;) maybe he could make "the most inner one which is 200 quid + from Nissan" :confused: :)
  14. Low oil pressure is a known 'fault' on the stock pressure sender Vibration WILL be worn prop centre bearing But as stated above, get it looked at by an expert
