anto300
    Ireland
Everything posted by anto300
  1. hi guys just wondering is dr a difference in the lenths between swb and 2x2 propshafts ?
  2. ic that waz a good result wazn it ! i for got to mention im getting a front mount for it to, i just dont want to have to raise the boost to high to achieve big power i want relability as i will be doing a bit of driveing in it.how about cams do they make much of a difference ?
  3. hi im starting to tune my 300zx tt manual and im hopeing to achive around 360 - 380 and waz just wondering what it would take to reach this number ? so far i have apexi air filter , trust sp2 exasust system no cats , hks boost controller , and a zed world chippt ecu 2 b fitted.
  4. anto300 replied to KIM's topic in Events - UK
    10.anto300zx - anthony goucher - dublin- pearl white jdm 2+2 tt
  5. going to do a change of oil in the gear box and diff just wondering wat oil to use ?
  6. hows it goin iv just noticet my water pumps leaking n needs replaceing now im just wondering is it a hard job too do and what needs to be removed to get access , ie timeing belt an so on ?
  7. yehs mines a jap and the speedo works fine and i dont have a converter fitted,its just the rev counter that wont work when the power steering does.
  8. hi im haveing an on going problem with my power steering comeing and going.and iv just been checking wireing and if i disconect the rpm signal wire from the ecu the power steering works perfect no fault what so ever untill i conect the rpm wire back up ! does any one have any idea wat the problem is ? as i kinda want power steering and a rev counter ha ? ? ?
  9. yeh i az thinking of coils alrite gona get the split fire ones soon,and the car came in with a hks evc boost controller on it !
  10. any one else got any ideas pls ?
  11. nah its be fore the limiter even,and when change gear its stil the same jst wants to stall for a few seconds i have to kep the revs up to keep it running.
  12. hi i have a 92 zx tt j spec and when i drive it vry close or too the rev limiter it missfires and goes down a cylinder or too for a few sec,s and loss,s a lot of power till it clears out has this happend to any one be for ? ? ?
  13. anto300 replied to a post in a topic in General Discussions - 300ZX Related
    my car came in from japan running 1 trust blow off valve n its fine !
  14. ah no probs, yeh they are quite pricey alrite an i dont thnk they even make them ne more now !
  15. hey yeh iv got one and i thnk its worth getting it pulls a nice bit stronger after i fitted this to mine and they are a vry good fit.
  16. hi guys that infact is a border-racing induction kit ! and i actuly hav 1 under the stairs as it happns ha.
  17. hey id be up for going to shud hav my car bk on the road thuesday r wednesday.
  18. yes well iv got it done just haven fitted it yet cars in getn work done at the mo ! will post results wn fitted and test
  19. ok well its jap alrite but its still in kph and still restrickted.may be il try the speed sender then but i waz told if my speedo waz working then it wouldn be that is this true ?
  20. em im not a hundred percent 2 be honist but i waz told 2 try that first,the problem is when im driveing along the steering just goes heavy and when i turn the ignision off n on again its fine for a few more miles have you any ideas ?
  21. hi i have a fault with my power steering and i waz told to replace the solinoid and i waz just wondering were its locatid as i have a good solinoid to go in.
  22. ok cheers lads i think il give it ago an see how it goes an il post dyno results as they say theres a 70bhp increase with the chip !
  23. hi just wondering if any body has used there chip and what were the results ?
  24. hi i was just wondering if the uk lights fit into the jap spec z32 with out a problem or what has to be done to make them fit ie wire in i mean.
  25. hi there im trying to find an apexi power fc for my 92 zx fairlady and cant seem to find ! does any one know if there is one producest for my car ? and if would they have a part number ! cheers.
