electric window motor and arm
gonna be changing this, is there a How 2 for doing this?
also is there a way of getting the door card off without damaging it, its one with the seat beats on the door.
Getting the door car off without damaging it? LOL. As with all things, if you do it properly, you damage nothing!
Door trim removal
PS, regarding the window motor. Have you checked that the regulator is working? Saves a lot of time and hassle if it's just this that's fault.
My window dont open, makes it hard to do without damaging it! cant get the top part of the door card off:(
The top part? You mean the trim that the belt sits infront of? You actually need to have the window down for that as behind the window is a small plastic cover that you need to pop off. There'll be a nut behind that. The base of that peice of trim is secured at the bottom via a bracked and 2 small screws. The door-card clips onto that. You don't need to take it off to get the door card off.
....how did you test the motor with the door-card on then? You must have had it off before?
got it all off, tested the new motor and didn't work. wired it directly to the battery and works. think it might be the black box. how do i repair this?
I just said that in the second post!! You can repair them or replace them. It'll be a dry joint no doubt.
fixed the black box, it will now go down. switch is also broken and wont go up:headvswal:headvswal
Is it possible to dismantle the circuit from the switch?
