Bypassed boost soleniods only 0.6 bar
When I put my engine back in I bypassed the stock boost solenoids as one was faulty! Now I am only getting 0.6bar with no boost leaks as I tested for boost leaks today.
I connected the pressure feed pipes directly to the wastegates and plugged the other two pipes to the turbo inlet. I have a feeling I should have tee'd these Doh!
Doe's this make sense?
Edited by (Z)Master
Are you trying to plump in an EBC?
yes :)
Need to tee the feeds to the actuators to the NO valve, the pipes that come off the back of the intercoolers need to be tee'd up to the common IIRC.
