power steering playing up
My power steering is always been light to turn , yesterday started the car from hot and the steering needed more force than it should , happend again today, then after a couple of miles returns to normal , can i flush the system out !(
check the belt aint slippin 1st
Thats all fine , and also when the engine is off the resivior is at the right level, engine running leval drops so pump is fine havent got hicas by the way
you need to have the motor running to check level after going from lock to lock 4-6 times then re-check with motor still running
Just done done ,that all seems well ,
Any excessive noise from the pump when turning ?
Tbh..PAS faults are more often than not an electrical fault. The system is speed sensitive and if it loses speed signal it reverts to a heavy PAS state.
Pump, no change of noise
has not got a converter as it is still restricted but it has had the speedo dial face changed aparantly
What does the Face read up to ? if its more than 120mph (eg. 160 - 180mph) then its got some sort of converter or resistor modification.
Cant get to go faster than 115-20 sussexstu said the other day its not been deristricted
as far as i can tell the whole car is comp/ standard
I mean what does the speedo face go up to....not the car. If its in MPH, does the speedo show numbers only up to 110mph, or does it go right up to 180mph, as you cant just change the face without fitting a speedo convertor or it wont be correct.
Sorry , the speedo goes up to 180mph
you can if youve got the right speedo to start with ie 300kph
yeh, there is a Nismo 300kph aftermarket speedo available. Its pretty rare though and its just a stock speedo, with 300kph faces and a different resistor.
So do i need to replace a resistor or the whole speedo gauge
always thought they were a standard fitment both my z's had the 300kph dials when i got them.
:confused:
does your speedo work properly if it does then faults probably somewhere else.
Yep all works fine ,so i am going to take the rack off and get it refurbished ,just to be sure thanks for the help
i would check wiring, connectors and solenoid first, solenoids can be good for breaking down when they get hot ,couple of miles driving and some cool air over soleniod cools it down and it starts working again.
Can you tell me where the solenoid is , as after a short drive it clears thanks
its on steering rack drivers side where steering columb connects to rack.
Thanks for that, look into that first
