turbo timer connector?
Trying to fit a turbo timer but cant find the 3pin connector to connect it to.... i presume its in the steering column somewhere but cant find it? any ideas?
i know when i fitted my greddy timer needed to buy the extra harness to make it easy connection so wired it in me self
dan.:D
dan.:D
Ive got the connector just cant find where behind the dash to plug it into.
you use that to join the turbo timer to the ignition switch via the connector if that makes sense!
dan.:D
Sorry im being a bit thick but dont understand... have you got a picture?
still no luck.....
If you have vehicle specific harness then it goes between the Ignition switch and the original ignition switch connector. (ie unplug ignition connector of back of ignition, plug it into your harness and the other end of your harness into igntiion switch).
If you dont have vehicles specific harness then you will have to cut plug of and hardwire it.
yeah what legrath said i didnt splash out on the harness so wired mines in directly.
dan.:D
Cheers for everything guys, ended up wiring it in directly and works fine now.
