  • Replies 64
  • Views 1.7k
spacer ring is a close fit on wheel hub and its outside size is a close fit to centre of brake disc same idea as spigot rings for alloy wheels.
gtr discs will fit straight on the 300 same pcd and bore size. all you need is the correct size brackets for calipers.
remember thats £125 per disc, personaly dont think thats cheap at all.
check ebay mate got loads o different discs on there or you can have mine for £100 plus postage and i'll throw in the spacer rings.not many miles on them and all in good condition, only getting rid of them cos iv'e got a set of 350 x 35mm willwoods and brembo calipers to go with them.
OK sounds like the best option. Would that include the brakets so all I need to get is the bolts?
Would be interested to see if they fit under your 17s
includes everything but the bolts will check tomorrow with fitment for 17"s
Nice one, the spokes on my wheels come outward and have a fair bit of room under them.
I'm running 10mm spacers at the moment to correct the offset and could probably do with changing them for 15mm.
17"s fit fine theres a approx 20mm clearance all round thats with a 15mm spacer fitted.
discs have got a bit of surface rust on them but i will clean them up.
Yeah I dont think they will be a problem, they will look massive under 17s :)
They do look like they need a clean though!
Should fit with my 10mm spacers on. If I changed them for some 15mm ones would I be risking breaking the studs? Do the ones you have fitted have thier own studs in?
yep my spacers are bolt on type reckon you would still have a good 10/15mm clearance with your own spacers.
Yeah I might just stick with the 10mm ones and save my arch liners lol
Hope they clean up ok, is there a way of stopping the hub parts of them from going rusty again?
Black or silver hameright smooth spray :)
yeah they'll lean up no problem looks worse than it is, its only surface rust and as car mad says paint will keep areas not touched by pads clean.
Yeah mine on the car look almost as bad and it was driven 2 days ago!
my new setup willwood 350 x 35mm discs and bembo calipers
disc compared to 17" wheel
so hav imanaged to sell you discs and brackets.
They are huge lol
Yeah I'll have them but would you be ok to hold for a couple of weeks till I get paid again? Also would like to see them cleaned up etc :)
no problem mate will clean them up sometime this week and post up pics.
Great stuff, will be wanting to hammerite the hub bits of them etc.
I'll definately have them off you, just building the kit up, they probably wont go on till after xmas as I'll need to get some pads etc as well.
got a set of mintex extreme pads that were being used with discs approx 8 mm left on them £20 if you want them with discs.
