head gasket sniffer
want to do a test on mates car what and where can we get the sniffer tester seen used?
dan.:)
  • Replies 102
  • Views 3.6k
Good luck with it Dan and dont get disheartened if it doesnt run like a peach straight away.You may have a few bad connections that will need checking and cleaning.Just work your way through and if it floods it will be a pig to restart.Pull the plugs out for ten minutes and dry them.
that engine looks very nice in them colours are you going tobe doing a start up video???
its yts weasel car and i got every faith we can do it! if not i will be ringing my jedi master! keep your phone with you paul:x: i think we may record something i remember paul did a video of mines the first time and i bloody deleted it!:(
dan.:rofl:
TOMMORROW is the BIG DAY! and it so happens to be yts weasels (west) birthday lets hope its a good one, caribzx is coming over anyone in the area is welcome along around 2pm-ish St.Earth Ind estate. (its not a MEET!:x:)
dan.:)
Well!....Did it work and wheres the pics!!
Can't stand the suspense!!
Dave
Dave
NO!!!!!!!!!!!!! it bleedin didnt.:( everything done and ready to go turn the key and nothing, can hear the fuel pump prime up but nothing! not turning over, i had to go so couldnt sort it out :headvswal
dan.:mad:
IT'S ALIVE!!!!!!!!!:hyper::hyper:
bit lumpy but getting there, back again tommorrow night!:D
dan.:D
WOOHOO looking good
thanks matey hope you feel better soon xx:duffer:
dan.:D
so do i mate hope you have a wonderful Xmas
same back at you and all yours.:D
dan.:D
ARGGGHHHHH!:headvswal
we got murky oil which stinks of petrol! only bin running for about 2 mins on and off not even warmed it up and no spark at coilpack 2 and code 34 with resistor!
dan.:mad:
Edited by dannzx
update
we are nearly there to welcoming another zed to the cornish list!:hyper:
dan.:)
got her running nearly there just got some timing issues! cant seem to set the timing correctly at 15degrees idle it is way out!:headvswal
dan.:mad:
what RPM are you setting the timing at ?
850-900rpm was showing around 28degrees!
dan.:)
make sure engine is fully warmed up (coolant >70C), before checking/setting timing.
also if the car has been converted from auto to manual the timing will be "fixed" to 25 BTDC at idle unless you connected the Neutral switch of the gearbox to the ECU.
-Eric
-Eric
its an auto & was in Netral when checked & warmed up >70
think i'm one tooth out on the bottom pully :( belt off again!!!!!!
following a guide to set timing and it mentions plug wire extension where can you get this from?
dan.:D
-Eric
how is this done?
dan.:D
tonight we mostly been fitting dump valves and body kit, will put some pictures and video up when i work it out!:confused:
dan.:)
Snow plough fitted in time for the snow :rofl:
dont get west started on his front end!:slap::rofl:
dan.:)
