H3, H3c, H3u
Which one of those should fit my Z
It's a jdm N/A.
I bought h3c after looking back through the forum but the ones i took out seem to have h3U written on them.
The bulb i took out has a white "tail" and is considearbly shorter than the first but when i plug it into the loom it still lights up. can i keep using them?
  • Replies 29
  • Views 3.2k
thanks Dan bulbs arrived friday and all fitted,look GREAT:hyper: if anyone can make use of the hid bulbs had originally drop me a line you can have em :D
thanks again.
dan.:)
Glad to hear it all worked out! :)
Further to your post above, from the picture you posted it appears to be a 4300K 9006 bulb (these are commonly found in US-Spec Zeds).
Dan
  • 5 months later...
sorry to bring this up again!:o while i got the bumper off i want to get the hid's to stay on with main beam so after reading through i need to ground one of the wires from the hid bulbs as shown in picture?
dan.:)
dan.:)
NO! Not those wires as these are the ones that plug onto the ballast. The one you need to earth is (usually) the black wire with the flat spade connector on it. This will come from the ballast (big grey plug) and end with a red & black wire with spade connectors on it. Plug the red one into the wiring loom connector (ie, little grey box) and earth the black one to the chassis.
Dan
Dan
:bow::duffer: thanks dan no wonder i couldnt get it to work!:slap::rofl:
dan.:D
