Next the Gearbox
once the props out then theres the box can anyone tell me what to expect or what to do next with the gearbox for engine out job.what i mean is do i just unbolt and ? sorry for sounding dumb
Be careful, the gearbox aint light especially when wet.
Need to remove the wiring and starter motor.
Brace and jack around the drain plug as thats about the centre of gravity. It has a tendancy to fall to the passenger side iirc.
You'll need to strap it up. There are ten bolts i think, two you will need to access from the engine bay. Then its a matter of backing up the box and lower at the same time so that the plastic speed sensor clears, it's fragile so be careful.
HTHU
So i undo two nuts from engine bay the starter moter and any wiring to it then slowly undo all the others whilst putting a jack under and poss a spare wheel at back end to help me out because ill be on my own,and im still yet to find out where the best place is to undo the prop at which end
