hi all
does anyone know the name of the little thingy that pulls the chip out from a socketed e.c.u.?:D
every time i pull the chip out to test or change i damage the chip i am trying to remove:(
i know they sell them on e-bay and at maplins, but i need to know what it is called so i can search.:)
cheers,
al.
flat head screwdriver :smash:
nice one matey:rofl::rofl:
i need the correct tool, as want to chop and change a bit to try things out.
al.
the main thing is to make sure the pins go in straight and to remove use a couple of watch makers screw drivers and prise it out evenly on both sides:)
cheers znut,
but there is a specific tool for the job, and i have wasted so many chips!!
cheers mate,
aL.
Its called a chip extractor, maplin sells them cheap
ive never seen them but they must be better than this:D
hi mtl
searched maplins for a "chip extractor" and cant find it:cry:
al:D
That would not surprise me :rofl:
i like it znut!!!! nice one!!
bios extractor, thats it, cheers mate.
al.
are you sure our not frying the chips, need to ideally do electronic on a earth mat with an earth strap?
Ignore me otherwise :p
when you are pulling the eeprom make sure you are earthed ..static is the biggest killer of silicone chips....and i dont mean earthed to the battery negative ...take a thin wire and attatch it to your wrist .....if you wear a metal watch thats agood place to connect the bare end of the wire.....the other end ( bare cores ) wrap around a big screwdriver shaft and stick it in the garden .....
On a side note if you are gonna change chips in your ecu a lot i would recomend fitting a ZIF socket, makes changing a chip easy as flicking a leaver and lifting out.
hey mtl
"ZIF SOCKET" dont know what this is, have u got any pics and info where to get it from?
cheers mate,
al.
ZIF=Zero Insertion Force
It's a type of socket that accepts a chip. You solder the socket to the board but just press the chip into this 'device' no soldering required to the chip.
HTH dude.
HTH dude.
cheers dunk :bow:
al ;)
