got given new standard air filters tonight replaced the old ones[ realy thick crud on them ] impressed with the difrence that made ,so when i put the induction kit on how much difrence will that be
In terms of more power etc?
If you get an aftermarket induction kit it will increase the power by a little bit, nothing seriously really.
Just a little FYI if you did full sentences and used grammar, alot more people would reply to your posts :)
sorry, didnt ask for an english lesson, thanks anyway.
An induction kit provides very little benefit without other mods, if your running bigger boost and a different ecu map then yes it makes a difference, but on a stock system its a bit of a chocolate teapot.
Plus if your still using std recircs youll suffer goose honk too.
ta for a reply made sense but the meaning of goose honk too ! dont understand
Its air coming back up the intake i belive and the cone filter acting as a big trumpet, you still get it with stock filters but the air box muffles the sound.
My goose honk stopped when the turbos were rebuilt it's about the only problem that was solved
hummm, always thought it was the recircs leaking??
i stand corrected;)
You are right it is, but the air goes back up the pipe as far as i can remeber.
Im unclear on the exact cause/reasons of the goose honk noise, but you wont hear it just from fitting an induction kit, unless there is a problem(ie leaking recircs) Its pretty rare tbh
Murt, along with everyone else was only trying to help. If you do ask for assistance on here, the least you can do is make your question easy to read. There's no reason to get funny about it!
Hey bud :) If you're looking into induction kits there are lots available, i personally went for the Blitz SUS, far from the cheapest but it has been excellent for me, and also people with the SUS don't seem to get the problem of a wet MAF ;) :)
Thank you
