Fuel pump relay help?
I an now going to take all fuel out of car because of engine out job. on fist illistration it says as follows.
1. Remove the driver's kickpanel, 2 screws are in the side of the panel, 2 are in the firewall, the last one is under the carpet by the dead pedal (5 x phillips). Remove the first two screws of the door jamb's plastic trim (2 x phillips). The kickpanel interlocks with the front edge of the door jamb trim. Disconnect the fuel pump relay (bright green in my '95) in the driver's kickpanel (1.).
2. Unscrew the gas cap to remove any residual tank pressure. Start the engine & let it run until it stalls, crank it over a few more times to relieve all the fuel pressure.
3. Reconnect the fuel pump relay. Replace the kick panel. DO NOT turn the key to ON, it will run the fuel pump and try to repressurize the system.
4. Put towels under the fuel filter to catch any gasoline. No smoking or any other flamable activity while doing this! I can't believe I need to put a disclaimer in there like this.
5. Loosen the fuel hose clamps (2 x phillips). Use a straight screwriver & pry the fuel lines off the old filter (2.). Be careful if the lines have retained any residual pressure not to get sprayed with gasoline.
6. Remove the filter from the holding bracket (1 x 10mm). Remove the towels from the engine bay.
7. Install new filter with the flat side facing the engine. Reconnect the bracket (1 x 10mm) & fuel lines. Tighten the clamps about 3mm from the end of the hoses (2 x phillips). Torque to 0.7-1.1 ft-lbs.
OK MY CAR IS MAN TT 1990.AND I CANT SEE THE BIG GREEN RELAY WHERE THE ILLISTRATION SAYS ITHOUGHT IT WAS THE ONE UNDER THE BONNET BUT IF I WAS TO TAKE THIS OUT I CANT START THE CAR. MY QUESTION IS SHOULD I JUST LEAVE THIS IN ,START CAR UNTIL IT CUTS OUT. BECAUSE THE BATTERYS OF NEXT ANYWAY?
Remove petrol cap.
Lift bonnet, look on drivers side, small sloping fuse box next to brake/clutch booster. Lift lid, pull fuse on the end ( also shown on lid) turn key a few times, done!
smithy
