Jap or UK Rear lights
Hi when looking to replace the rear lights on the Z are the jap and uk ones the same?
I am looking to get replacement rear lights for a UK Series 1 tt so will there be any difference if I get lights off a jap car? Will the lights need modding if I try using the jap lights on a uk car?
I have seen a few lights for sale but they are all jap and I would rather know first before getting any surprises when it comes to fitting the lights in.
  • Replies 27
  • Views 1k
I have a a set of ones off my UK car with no cracks in them at all. After £50 plus delivery, can send you pics if you want :)
Vijay
original off a 92 series 2 car
mine have a couple of hair line cracks but am gona hold out for 99 spec type or clear in some form but thanks for info & quick reply :D
Do it yourself, i did it (check out my ride). Its not a difficult job :)
Thanks for the info guys much appreciated, now I know what is needed.
do it yourself, i did it (check out my ride). Its not a difficult job :)
hey m8 just had another peek at ur pics so is it just a case of replacing the inner coloured light strip ??
As have seen somthin like that on e-bay ie clear white panels that would sit behind the outer lens ??
Is that sort of how it works ??
Ck300z:d
Ck300z:d
You got it in one bud :D
When you buy the lenses off ebay, they come with some very basic instructions. All you need to do it take the lights off your car, heat them up and ply them apart and then take out the orange difusser and slip in the clear one, them stick them back together and jobs a good un' :D
I also bought some pinstripes and made mine look even more like 99s. :D
cool thought so !!
thats a must after the service lol not too expensive off good old eb either thanks for the info :-)
anyone have a link to the clear lenses?
if you want to do it on the cheap with the light you have now
edit
the link from the "free modifications" thread doesnt work anymore
i can provide u with the item number of e bay and seller info ??
please :)
item no is 160281285839 and seller is lisaf6183
and item is listed under
Clear light conversion Nissan 300zx
will prob snap some up my self on pay day :):)
Cheers bud :) Am I right in saying they can be made out of the refractor stuff from flurenscent light casings?
not sure on that one m8 but zx-eyes will prob know as he's fitted his
give him a shout:D
My ears are burning :rofl: :rofl:
It is basically a plastic clear diffuser, no doubt you can source it from various shops etc.... however when you buy them pre cut its an awful lot less messing about! You can literally just slide them straight in and the job is done. :)
mmmmhhhh considering my diy skills think ill go for the pre cut version lol:rofl:
:rofl: :rofl:
Good choice ;) :D
Also regarding cutting your own, you'd have to spend time finding the right stuff and my time is worth more to me, lol :D
I bought some clear lenses off Ebay and ruined one of my rear light clusters trying to pry it apart. I had got the cluster nice and hot, but the glue substance was still very sticky and I damaged the plastic pulling it apart. The glue is very messy as well and its easy to get it on the new clear lense.
I ended up buying the OEM 99 spec brand new from the States. They worked out at £200 included taxes & delivery (center panel not included). My original center panel was refitted and does not stand out badly against the new ones at all.
At least I tried! I'm sure the conversion works for many, but not for me & I've read on this Forum others have failed too.
Just offering another spin on this topic.
yes its the clear light diffuser from strip lights or the big square one they put in on tiled office ceilings, I did this on my last zed, used a hairdryer to heat them up and wd40 to remove any mess when i finished. extreamly easy mod, ignore the write ups about using an over.
A conventional hairdryer or heat gun will do the trick but beware your fingers will burn if you use that hairdryer to long
My girlfriends kept cutting out because it was getting to hot, was really annoying.
But when you unbolt them from the car, beware that they are held on with the same glue so you need to add heat to remove them and heat to put them back on.
