protoj · Tuesday at 18:48 4 days
Hello mate,
Was looking through the For Sale section and might be interested in the gauges you have. Can you drop me a mail at karl.bowles(AT)ntc-europe.co.uk, preferably with a pic if they are still available?
Ta!
