cam belt
hi guys just done a cam belt on my zed it was running before the job was done but now have no spark at the coil packs done a fault code test and came up all clear could anyone help please many thanks,
hi scott thank you for your reply yes i think so as the connectors only fit one way round but i will check again
When I did my cam belt I put the PTU back on, but some of the pins inside the socket had been pushed back so it looked ok from the outside, but was missing when started.
:bow:thank you guys could it be that the cas is fitted wrongly as i was told it could be fitted 2 ways is this true
