hi gents, i have a 1990 300ZX TT, does anyone know where i can get some wheel spacers with extended nuts, as the alloys i bought do not have enough clearance at the front.
Depends on how much clearance you need to gain, if you use 3 or 5mm spacers, the nuts or studs as it were don't need extending.
I have 3mm spacers all round and have had no problems.
You can buy these spacers from Ebay for a few quid.......
If you use more than 5mm spacers then you will need to extend the studs.
These kits are available from Ebay as well, but cost a lot more because they are a kit.
Specialist 300zx shops such as Zcenter also sell the bigger spacers.
Like a said though, if only extending by 3/5mm, buy from Ebay, cheap and no need to extend studs.
Have a bounce around and see.......
HTH:)
thanks i appreciate the response, but i need 25mm, ive just order some anyway, but thanks.
For 25mm you will need hub centric spacers. It begs the question though, what kind of wheels do you have that require this much spacing?
25mm isn't a lot. I fitted the same to the front of my car to get the wheels kicked right out into the arch. It's quite a common thing for those that want the stance to look good and you want more than just hubcentric spacers. He wants the bold-to-hub versions of that. Extended wheel studs is a no-no.
Get Eibach spacers for the Z33. Same PCD and centre-bore, so you should be fine. It's what I run on mine.
These are normal hubcentric spacers which you really don't want!
These are bolt-on hubcentric spacers which are what you want...
You bolt the spacer to the hub and the wheel to the spacer rather than running an extended stud through all 3!
