ambiant temp -86 ???
just got the car runing again,filling it up with fluids
noticed ambiant temp reading on left hand side pod was reading -86
anyone any ideas ????
cooor its cold up there LOL
you havent knocked/pulled the outside temp sensor on the front bumper have you
where is it ???
any pics ???
front bumper is off so might of done if thats where it is
If you look in the online manual there is a section in the electrical part that tells you what the fault codes are as thats probably what it is?
I belive its just on the left side of the splash guard plastic thing, connector is next to the aircon tank thingy. you may have forgoten to disconnect it while pulling the bumper off... oops.
Its a little black box about 3cm x 1.5cm x 1.5cm with a bolt hole going through it. Black lead coming of it that goes to a little connector. Should be able to find it under the nose panel, behind the bumper towards the drivers side.
