19" Rims
Hi all, been thinking about getting some 19" rims for the Z, do any of you have any comments or advise, how wide and what offset? before I take the plunge.These are what I've been looking at.
cheers Paul
Edited by 300_zedx
Pictures added
Ive just fitted a set of 19s to my z they look perfect with the rears being 9.5inches wide with 265 30 19 and the front 8.5inches with 235 35 19 they really do make a big difference in the looks department and the handling, not sure on the offset ill have to check i cant remember.
That would be a big help to know what offset you have,
cheers Paul
Paul,
This is taken from the FAQ section (brakes & suspension):
PCD
5 x 114.3
Offset
+35...42 mm
Centre bore 66 mm
The off-set is a range because a lot of wheels have varying dish depth. You can therefore get away with a slightly different off-set than on stock wheels.
With regard to handling characteristics - that will be due to the unsprung weight changing when you use different rims. For example, I've got a set of 19" Kahn RS-C 2-piece rims and they weigh a tonne compared to some other forged rims which are light as a feather.
Dan
Edited by DTA (UK)
Personally I don't think you need to get anything bigger than 18" on the Z. This also saves on wheel and tyre costs.
I would go for a +35 offset with a 9.5" rear rim , and +25 offset with a 8.5" front rim.
thats what i got on mine.. perfect combo IMO....
Show Off :tongue: :rofl:
Seriously though looks sweet! :D
Well mates I have 20's on mine, back in the USA.
It looks sweet and it rides well.
How about posting some pictures up.
Paul
