double din headunits
has anyone fitted a double din unit in their zed? If so how hard was it to fit as im thinking of doing it in mine when i get it back
Membership No 0780
INSURANCE GOOFA
have a word with funky. hes fitted one but imported the surround.
im sure he'll be along soon, he doesn't miss much on here
Membership No 0780
INSURANCE GOOFA
not cheap around 125 quid imported :0
i am looking for a spare to hack around and see if i can
find a way of making a cheaper version .....if anybody has a spare that is :)
Dan at Smithys /DTA can probably get them if you really want one
steve
so once you have the front done making it a double plot then how hard is it to fit
Membership No 0780
INSURANCE GOOFA
should be easy to fit. it just fastens to the brackets thats normally there, unless like mine & there aint none. easy enough to aquire though.
its the room behind for the cables that is the problem im sure Funky had some probs getting his fitted flush .
there is enough space defo..
i think you could sorta make 1 yourself...
you need to cut the middle bit away tho obv.
just use an angle grinder and file.
i had to cut loads of mine off the top, and around the endges to fit my gauges there....
