changing clutch
is this the same as other cars?
nothing stupipd like engine out isit?
estimating £100 labour?
mine is due, just want to plan some finances...
Straight forward job for any garage and average pricetends to be between 180-220 quid.
smithy
smithy
you should have told him to change the pivot ball as well Paul
whats this then?
so new clutch, new spigot bearing, and pivot ball?
Thats just the clutch disc on it's own and is for the non turbo fitment mate.
smithy
If you are running totally stock set up. Grab a new clutch from Mike Feeney in the trading section.
If you are running high boost or intend to up he power, grab yourself an RPS max street clutch from DTA motorsports also in the trading section.
Ask them to check the flywheel for you as well as if you have burnt your old clutch you may need it skimmed.
will be running basic stage 1 mods,
decats, chip, 14PSI, full exhaust & filter..
thanks dudes il ask now.
clutch isnt that bad at the mo, just i can feel it riding. so its next on the to do list! :)
