N/A rear diff on a TT
Hi,
How much of the rear of an N/A is needed to swap the diff onto a TT? Do the hubs get swapped over too?
Vijay
no just the subframe and diff itself including driveshafts.
got one if you want one ?
Although it can be easier just to swap the whole thing, including hubs, rather than dissassmble only the required bits
What is the advantage of that???
Cheers :)
4.08 ratio instead of a 3.69. Which means you gain acceleration with the sacrifice of some top speed. A very favorable modification by those that have done it.
Thanks David :)
Maybe a stupid question......but is it a noticible difference? And what does it reduce the top speed to?
Cheers guys, I've got one off an N/A already ;)
Thanks David :)
Im fitting a NA rear end in mine at the moment, but not yet driven it.
I've only been in a NA converted TT, so I did'nt see a Before and After Diff swap, but its impressively quick through the gears, and noticeably quicker than a Regular TT with comparable mods
But from everything I have read and those I have spoken to about it who have first hand experience they say its very noticable. I know one of the Tuners in the U.S did some comparitive tests on the same vehicle and found it knocked half a second of their 0-60 times.
Still capable of 165+ mph, and it will get there a lot sooner :)
WOW :eek: Half a second, very impressive! :D
Sorry to hijack, but would a TT diff fit in a N/A subframe?
I'm thinking of putting a N/A subframe on my TT so I can do away with the HICAS completely.
No, the mounting points are different. Have to fit NA subframe.
Are the N/A diffs LSD? And what sort of money?
Yes, L.S.D. We sell the Diff's desperately to NA owners for £100, or the entire Diff and subframe to TT owners wanting to convert for £200.
