protoj · Yesterday at 18:48 1 day
Ignore the title it was pearl white, doh. saturday afternoon at around 1.15 nice lookin pearl white zed with the same spoiler as james funge and a bit of a bodykit, just wondered if it was anyone on here?
Edited by snowygt
