auto gear box problem....help please
yesterday morning i was driving to work and suddenly the car it wont change in to 3 and 4 gear for some reason ,last night started the car again push the break to put in to gear but gear stick it wont move ,i can put it in gear if i press the little buton at the front but is still the same ,it wont change up.Please if anyone had similar problems let me know cos i really need the car to go to work
:dance:
  • Replies 28
  • Views 2.6k
i just donne a diagnostic and it came up 1 long flash and 10 long ones...
:dance:
http://www.twinturbo.net/ttnettech/autodiag/autodiag.html thats the code translation.
Error Codes:
All 10 flashes the same = No error codes detected.
1st flash longer than others = Revolution sensor is shorted or disconnected.
2nd flash longer than others = Speed sensor circuit is shorted or disconnected.
3rd flash longer than others = Throttle sensor circuit is shorted or disconnected.
4th flash longer than others = Shift solenoid "A" circuit is shorted or disconnected
5th flash longer than others = Shift solenoid "B" circuit is shorted or disconnected
6th flash longer than others = Overrun clutch solenoid circuit is shorted or disconnected
7th flash longer than others = Lock-up solenoid circuit is shorted or disconnected
8th flash longer than others = Fluid temperature sensor is disconnected or A/T control unit power source circuit is damaged.
9th flash longer than others = Engine revolution signal circuit is shorted or disconnected
10th flash longer than others = Line pressure solenoid circuit is shorted or disconnected
All the same with no long start flash = Battery low, been disconnected, or control unit has just been reconnected.
I believe its the speed sensor for the gearbox its self, that tells the gearbox ecu how quick the gearbox is turning over. Although im not sure!
there is a noise coming from behind the engine...between the engine and the gearbox where the torque converter is ..can it be the torque converter ????
:dance:
that means no errors.
The problem is mechanical. If your lucky then its either low on fliud or needs a fluid and filter change....otherwise its new or recon Box time Im afraid. Unfortunatly the syptons you describe is very common and typical of the autobox failure.
the thing is that i've changed the box about 6 months ago but still with a second hand one,the fluid is ok i've changed the oil and the filter when i put it on the car .I don't know much about how the torque converter works but can it run ok only for the first and second gear but not for the 3 and 4 ???
:dance:
  • 3 months later...
ok ..this realy piss me right off now...i've changed the gearbox again,everything was fine but i haven't drive the car since then, just took the car out today after 3 months ,done about 7 miles ,took it to a motoway floor it a bit ang then agan the same problem as before,gearbox it wont change in to 3 and 4 . done a diag for gearbox and it came up Revolution sensor.where is this sensor exacly and what it does ....exacly same problem with the other box pls help anyone
:dance:
Sounds like its goosed fella, classic 300 gearbox problem of the clutchpack being burnt out. Very much doubt you will be able to do anything exept get another box or recon that one (Better option) or always go for a manwell conversion.
If the rev sensor is the problem and not that your misunderstanding the fault codes then it is located on the passenger around half way down the length of box and two thirds up, it is fitted on the outside so can be changed without removal of the box etc. the exhaust can be in the way a bit but it is do-able.
If all else fails before giving up on the box ( again) I would consider swapping the autobox ecu for known working one.
Jeff TT
When you say you have done a diagnostic and recovered a fault code have you cleared the codes then roadtested/rechecked for codes. Is the same code coming up again? Not being familiar with these boxes there must be a resistance check for the sensor from the ecu as it could be wiring rather than the box that you have changed. I work on Allison/Voith/ZF boxes in buses and they all have different reactions to faults, what I mean by that is that if the fault is current the box might go into a 'get you home' mode thats why u only get 1st and 2nd. Go you not have a manual as it will open up the fault code to tell you what to check.
HTH Sorry for warbling.
Cheers John
Here it is fella, it might just be a bad connection seeing you have the same problem on both boxes.
ok just come back from ouside....and i go back again..:) to check the wire from Revolution sensor and if is ok then tomorrow after work i'll change the box ecu cos i've got another one and if nothing happends i'll try to change the Revolution sensor aswell ...discconected the batery aswell and still give me the some error...
:dance:
ok....i've checked the resistance on the revolution sensor and is 649 wich is good ,in the manual sais is got to be betwin 500 and 650 resistence ,changed the ecu box aswell with the ecu that wich came with this gearbox and is still give me the same error 1 ong flash and 10 short flashes wich if i'm not wrong is the revolution sensor. the next step is to check the wires from under the bonet to the gearbox ecu to see if are interrupted somewhere .any ideeas please let me know
:dance:
Keep your multi meter connected and have someone watch it while you pull at the wiring/connector and get them to shout if the resistance changes significantly and hopefully you will find the fault. Also the resistance being fine doesnt mean the sensor is ok it could still be nachered.
Cheers John
ok.... 1 ong flash and 10 short flashes wich if i'm not wrong is the revolution sensor.
as legrath said. That is the all clear code.
you disregard the first flash. it is the next 10 you are interested in.
i feel you pain though, mine seems to have done the exact same out of nowhere and im getting the ALL CLEAR. seriously pissed off with this car, problem after problem...:mad:
please anyone just to double check ..one longflash and 10 short flashes is all clear or is the Revolution sensor??? and also anyone knows a good gearbox specialist aroun london?
:dance:
Defo clear code.
Jeff TT
I had an issue very much like this on an imported Honda, I am new to Nissan so don't know the auto box but on the Honda it went from 1st and 2nd no issues but would not go into 3rd or 4th, I limped it to a gearbox place 30 miles away (which was really slow).
It turned out that the auto box had 2 clutches and due to fluid not getting all the way around the box and burnt the second clutch out.
this is exactly what is happeneing with mine the now gave up trying to find out why just going to save up for a manual however il keep checking here to see if you find it save me some money the now lol
I cant see why not! THere were some changes to later auto boxes i think which cured some earlier issues, but im not sure when it was... Anyway newer gearbox has to be better than an old one surely!
